Pdelcast
Pdelcast's Avatar
03.04.2009, 12:26 PM
Originally Posted by himalaya View Post
So these outrunners are designed for air applications? any possibility or advantage to use them in surface models?
Well, the issue with using an outrunner in surface applications is that the motors are very open -- easy to get sand, dirt, metal shavings, etc. into the motor. If you are using them in an application where it is a relatively "clean" application, you can use an outrunner. Otherwise, it's best to use an inrunner, which is much more sealed to the environment.
Patrick del Castillo
President, Principle Engineer
