03.04.2009, 01:14 PM
Originally Posted by skellyo View Post
If you want to take the pep out of it, either gear way down or drop your voltage down from 6S. Putting the 25T pinion on it is like trying to slow down a drag racer by putting monster truck tires on it...it's just not an intelligent solution to the problem. All you'll do is increase the current draw and start potentially causing heat issues.
The whole point behind what the guys from Castle are saying is to use common sense when gearing these trucks regardless of what the manual says. This post backs that up:
http://www.rc-monster.com/forum/show...&postcount=111
I think by pep he meant the large quantity of torque. Gearing up will put more load on the motor, and may cause it to spool up a bit slower, but it is not a good idea. Maybe adding some more punch control, or some expo to the throttle channel... I guess the CC motor is just too powerful for him
