Why??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Why?? - 03.04.2009, 09:57 PM
WHy do you need a 17mm nut. I just used the 17mm hex adapter and clamped it between two nuts and washers on the shaft. It works great and it is terribly easy to remove and install a wheel to do the balancing work. YOu have to think outside the box sometimes to achieve your goal. I like the look of the Hudy balancer. Maybe you can remove the bottom plate and extend the balancer somehow by threading a piece of allthread into the stantion, and mounting it directly onto your workbench. I am sure there is a way to make it work for MT wheels.
SUPERMAXX YOUR LIFE.
