Originally Posted by auto2
if you lock the ctr diff it will flip over backwards. also it will push going into a turn. have less steering. if yu just bash it might not matter. cant hurt to experiment with oils.
Does the 808 use the same diffs as the HPI lightning setup? If so you can put a locker (
http://www3.towerhobbies.com/cgi-bin...3&I=LXNWS7&P=K) in the diff if you wish.
