skellyo
skellyo's Avatar
03.05.2009, 09:34 AM
Originally Posted by fastbaja5b View Post
It seems ur not safe unless you have 8000mah 40C 3s Lipos and only maxcramps makes those claims!
That's not really true. IMO, unless you go stupid high on the gearing and tire size, high quality 25C/50C 4000mAh cells are more than enough for running the Flux on 6S. The chances that you're going to be drawing 100A continuous is slim to none. 6S 25C 4000mAh packs ideally can output almost 3HP of power continuously. There's no way in hell you're going to be pulling that kind of power continuously.
