12.07.2005, 10:33 PM
So, the maxx sliders held up fine under the torque of the BL setup. I suppose those would be easier to install since they can slide in to install and then slide out into the shaft outputs.
How did you install the custom dog bones since they don't telescope? Did you have to remove the front and back ends to fit them, or did you remove the tranny and work them in place while re-installing the tranny?
I measured the lengths I would need and came up with 93mm for the front and 98mm for the rear. These measurements are from the center of the tranny output shaft hole to the center of the rear/front differential shaft output hole. What lengths were yours? I imagine they were about the same +/- a mm or two since I am using the same setup.
