rabosi
03.05.2009, 11:15 PM
The tray is 207mm x 30mm x 42mm. The cover will allow another approx 8mm for a total height of about 50mm. Because of the design however (shape of cover and hinge location) I don't think you'll be able to fit a 30mm x 50mm pack. Also some dremel work may be required to get the battery wires exited properly depending on their assembled config. I really hope someone comes out with a better option.
