sikeston34m
sikeston34m's Avatar
03.06.2009, 12:23 AM
Looks interesting, but it is not a charge thru desing, correct? So it will not interrupt the charge should one cell go over 4.2... Unless it is hooked into the matching xtrema charger...
I like the on screen info, should work for your uses!
It is not a charge though design, but.........
With the MRC Superbrain 989, set the charging amperage to .5
This is right at the amperage the balancer discharges at. The charger is trying to charge all the cells, while the balancer is knocking the tops off the cells that have more voltage.
This method takes awhile but is effective.
