sikeston34m
sikeston34m's Avatar
03.06.2009, 12:37 AM
Originally Posted by MetalMan View Post
How are the tolerances on the input shaft (diameter)? I was thinking more along the lines of buying a die and modifying the original motor shaft, but your idea obviously requires a lot less work
The Tolerances are good!
The bearings of the motor AND the bearing used in the transmissions have the same ID. Very nice fit. I just tried the input shaft into a 2826 that I have here.
The 2826/8 won't work with this type of gearing, but a lower kv motor would. I'll have to plug some ratios/kv's in and see what pops out.
