Thread: Savage XL-E
Savy build
tklemin
Savy build - 03.06.2009, 09:15 PM
Thanks for the props. I was trying to make the baddest truck Ive ever owned. The motor plate is from KD. It just has a double mount for brushed motors I guess. The weight distribution probably could be a little better, But the batts still sit pretty low in the truck, and I still have the hump pack in the box that evens out a little. That was part of the reason I used the XL chassis. I figured the the longer chassis would even out the weight of the more rear weight of the batts. I just like the look of the batts tucked in, and it might ad a little more clearance under the truck and protect the lipos also. It drives great (not to flippy). As with most 6s trucks it takes a more dialed in throttle control than with gas. It took a few charges to learn to drive again. With my gearing It will still do standing back flips, but its not to bad after half speed.
ID:	6528   Click image for larger version
ID:	6529   Click image for larger version
