Thread: 17mm hex
Finnster
KillaHurtz
Finnster's Avatar
03.08.2009, 08:23 AM
Finnster - do you get any wobble out of that? In the top pic, it looks as though you've got a little runout issue on the spliced shaft - but it may be an optical illusion.
Not entirely sure what you mean, but I forgot to note that I had to sandpaper the pushrod adapter I made just a bit to make it fit nicely. As said I don't have a drill press yet (always on the wish list..) and I used a SAE bit to drill out the hex. The adapter was made as close to straight as I can make it by hand. Its quite tight and no wobble, but slides on easy enough.
