Originally Posted by Jason
It will work with a few mods. Open the center hole up with a reamer to match the slipper bearing. and you will also have to open up 3 of te smaller holes to fit over the slipper screw vosses so that the spur will fit flat on the slipper. Really easy, will take you 1-2 minutes, max.
