03.09.2009, 12:41 PM
You have to stretch the tire a bit to get it over the beads. Also be sure that the foam isn't wadding up.
Another trick before gluing the tires...
Scuff the bead of the wheels and tires with some scotchbrite and clean the surfaces with some alcohol to remove any residue. This will help immensely in getting the tire adhered to the wheel.
