03.09.2009, 07:24 PM
+2 to ditching the clutch. Lose the complication, gain reverse and motor braking.
If you need more of a flat, you may need to make one w/ a dremel or file. If the shaft is hitting the end of the clutch, then you cut off shaft or ditch clutch.
