Originally Posted by JERRY2KONE
... Plus there was a warning about the leads being designed backwards with the negative wire in the center of the plug. I hate when these companies do propriatory designs...
Yeah, I noticed that too. I just rewired the jack accordingly to have a negative sleeve/positive center pin (which is the way it should be). Then, I just used a RadioShack plug (size N or M - can't remember exactly now) and it fit perfectly in the stock jack. Then it was just a matter of wiring a small extension so I can use any NiMH charger.
