03.11.2009, 11:56 PM
Linc, looks good so far. The way you have your batteries was the method I initially wanted to do, but some people don't have nearly the lipo choices that you do!
I'm sure you'll be done far before I am because I still have to special order the "SE" Medusa motor (still undecided if I want a 50mm or 60mm motor), the ESC (MM and BEC), and fabricate the parts I need.
I do have a few lipos hanging around...
I hoe to finish it by the end of the week, or at least get it rolling... If it performs well up to 65 or so I will go all out... I also need to get my top speed tamiya back out and prep it for 100+mph runs... Time for some ceramic bearings...
Good luck on your build Brian, what speed do you want to get out of it?
