SV6000
SV6000's Avatar
03.12.2009, 07:25 AM
The traxxas ones are not worth it. The tekno ones are much better and easier to setup. Not that either one is complicated. Before you go and spend the money try changing the top A arm pins to lower the roll center. I liked that more than adding the sway bars. I bash and my setup is as follows. 50K in the center, yes my G3R has a center diff. 30K in the front and 4K in the rear. I like a truck with decent rebound on the shocks so i opted for a thinner oil and some stiffer springs, I also run the P3 rockers and have the ride height as low as i can. It handles superbly!!!! Well to my liking any way. But my truck is very light. It only just tips 4.5kg with the 6s setup. I was running a 1515 1Y but now i am thinking a 1521, the 1527 1D is very very heavy(around 750g) Just my two cents
