lutach
lutach's Avatar
03.12.2009, 02:12 PM
Originally Posted by jzemaxx View Post
Ok guys something I didn't think about and maybe some of the big brains can answer this. The HW150 automatically is set to 15 deg of timing. Now the question is, could this cause a problem with a Neu/CC motor. I know its a 4 pole vs HW 3674 2 pole motor. Do I need to maybe try lower timing on the NEU/CC to see if it picks up speed?? I read that the 4 poles like low timing versus high timing. 15 deg is quite a bit and didn't think of that. I just set both controllers to 15 deg since the HW was already set to that.
It actually depends on who you ask. I've heard many things like, "Our ESC switchs automacally to higher timing will gain more speed and power". I like the fact that some companies offer a simple answer. I go with 0 to 5 (Low) for 2 pole, 5 to 10 (Mid) for 4 pole, 10-15 (High) for 6 pole and outrunners likes 15 and more depending on the pole. One thing I do know is that D wound motors likes lower timing. I have yet to see any speed benefits from higher timing. I have seen heat from higher timing, but no other benefit as some say you can gain power from a higher timing. But what works for me will not always work for somebody else.
