jsr
03.12.2009, 09:39 PM
Thanks. I glued the rear endbell to help extend the time until the rear flies off and the motor spits its guts out. I don't mind if it does. If/when it does, I'll pick up a nicer motor. I like to develop setups with low cost motors. With my E-Savage, I used a low-cost motor when converting to brushless and I'm glad I did because I killed the motor from way overshimming my rear diff. I would've hated to do that to an expensive motor. Once the setup is working well and the low-cost motor dies, I'll pick up a Medusa.
