rchippie
rchippie's Avatar
03.12.2009, 10:19 PM
I believe I used one set of internal limiters.
I set it up to keep the links flat. Not sure how much clearance that is.
Note I'm new to this and not an expert by any means.
I used i thick & thin internal limiter per shock or just about 1/4 inch . With my links level i have 2 1/2 inch of clearence on the skid . One of my shock bodys is bad . so Horizon is sending me a new one . so i wont be able to use my truck for just a little longer . I also need two more 40mm screws to finish the stage 2 mod .
REAL MEN RUN BRUSHLESS
