Thread: Will it work?
Jeremy1976
03.13.2009, 12:16 PM
The stock slash gear is 48p... You can put the jato spurs on for use with 32p, or the revo spurs for mod1. You can use the 5mm bore 32p or mod1 pinions with the bore reducer for use with and 1/8 shaft motor.
32p 1/8 bore selection only goes up to 22t. I would go with the revo 40t spur and mod 1 gears.
So the Mod1 pinion will not work with the Stock slash spur correct? At least that is what I got from your reply. What Revo spur would be comparable to a stock 86t slash spur?? My goal is to run 23/86 an 25/86. Just not sure what the comparable Revo spur would be.
Thanks
