Thread: Will it work?
skellyo
skellyo's Avatar
03.13.2009, 12:25 PM
Originally Posted by Jeremy1976 View Post
I could not find any 32 pitch in 25t. Can the bore reducer that Mike has be used on any 5mm pinion such as the 32 pitch 5mm, or just the mod1? And can the 32 pitch be used with the stock Slash spur?
You need a 32P spur instead of the stock 86T, which is 48P.
You can get 32P traxxas spurs in the following sizes:
54, 56, 58, 62, 65, 68 and 72
You won't need a 25T pinion when the spur tooth count is dropped.
Also, yes, the bore reducer Mike sells will adapt a 5mm bore pinion (32P or Mod1) to a 1/8th shaft motor.
