Thread: Will it work?
Jeremy1976
03.13.2009, 12:27 PM
Originally Posted by skellyo View Post
You need a 32P spur instead of the stock 86T, which is 48P.
You can get 32P traxxas spurs in the following sizes:
54, 56, 58, 62, 65, 68 and 72
You won't need a 25T pinion when the spur tooth count is dropped.
Also, yes, the bore reducer Mike sells will adapt a 5mm bore pinion (32P or Mod1) to a 1/8th shaft motor.
Thanks, I sent you a pm.
