JThiessen
JThiessen's Avatar
03.13.2009, 07:52 PM
Originally Posted by kulangflow View Post
Unless you have a turbo, right? I've heard arguments on both sides, but the majority leaned toward not needing the backpressure as much if you had a turbo. Not positive myself though.
Originally Posted by cheesecake View Post
if its turbo 3 inch will be what you want the turbo actually acts as a muffler and creates a bit of back pressure
Geez...not sure how or what to respond. I'm in no way an expert on gasoline turbo systems, but I researched the crap out of my diesel system before I put anything on it. Its all about achieving a volumetric balance. Stuff in = stuff out. All these variables are part of a system, and without evaluating the system as a whole, you are throwing darts at the wall. If your intake system has the ability to put in more air than your exhaust can evacuate, them you need to change your exhaust. Most of the time this does not occur unless you have increased the induction system (ie. larger turbo, different cam profile, and actually achieve increased volume flow into the motor).
In the diesel world, one thing people do is they go and stick a 5" exhaust on, and drive around thinking they added 30 hp to their truck. 99% of them never bothered to look at the items they didnt replace - the Catalytic converter, and any of the components between there and where the collector on the exhaust manifold is. Any increase in your exhaust size over the smallest point in the entire system is generally a waste, HP wise. You are better off paying for a higher quality exhaust that has smoother mandrel bent bends than going bigger.
I've found that in lieu of buying a complete new intake system, you can purchase a high flow stock replacement filter, and mod your filter box with a dremel and a hole saw to increase air flow into the box. I've also seen guys use PVC pipe to make a smoother inlet pipe (from box to the turbo inlet). One thing you want to watch is to not create turbulance in the air at the turbo inlet. Some people have claimed to have good luck with a device that looks like a honeycomb that goes right in front of the turbo - it creates laminar flow of air into the turbo. I dont know if there are similar items for gasoline turbos or not, or if you guys would even need it at the low boost levels you see.
On edit....squee beat me to it....drat!!!!
