DARKWAV
03.13.2009, 10:49 PM
wanted a 36-50 or 36-60 Medusa motor where the wires exit the case like the 36-80 series does, as opposed to coming out the back. So, I emailed Medusa to see if a special motor could be made and this is what they sent:
Sure enough my RC-Monster order just came in and the version motor I got was the new MR-36-60-2200V2SE-5.
Side exit wires, plus the shaft extends out past the rear endbell a few mm. This motor came with the flatspot from the end all the way to the bearing...on both end so the shaft. I don't know if the flat always comes that way from Medusa or if that is just RC-M spec.
