MetalMan
MetalMan's Avatar
03.13.2009, 11:04 PM
Originally Posted by DARKWAV View Post
Sure enough my RC-Monster order just came in and the version motor I got was the new MR-36-60-2200V2SE-5.
Side exit wires, plus the shaft extends out past the rear endbell a few mm. This motor came with the flatspot from the end all the way to the bearing...on both end so the shaft. I don't know if the flat always comes that way from Medusa or if that is just RC-M spec.
The way the shaft is on that motor and the direction the wires exit is the same as on the 70mm and 80mm motors. They probably decided it would be a better choice all-around to have all their motors this way.
