E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.14.2009, 12:35 AM
Seems a bit hot considering the outside temp! Shouldn't be kicking the fan on at all in those temps. Is there a lot of snow sticking to the truck? Gearing is for about 35-36MPH I believe which should be easy for that setup. 160 isn't horrible but 98 on the lipos in 5* ambient isn't great or the fact that the fan on the MMM is on. I'd def play with the gearing, gear down if the snow is sticking to your truck resulting in a 20lbs snowball at the end of your run! Which ever way you go, check temps often!
