Unsullied_Spy
Unsullied_Spy's Avatar
03.14.2009, 06:20 AM
Originally Posted by Jeremy1976 View Post
Just looked at it again and it should work. It is not completely lined up but the mesh is good.
That's good enough for now. Seriously though, go with Rootar's advice and get the nastiest gears you can get. 32p will be fine and you can get 32p pinions in the 1/8th inch shaft and it will be leaps-and-bounds stronger than the 48p gears you're using now. With one of Mike's bore reducers you could run a Mod1 gear on there (should have gotten a 5mm shaft from the start but you live and learn) and a Revo spur gear. If you strip a Revo spur gear in an ER you've got either mesh or bearing problems.
