SpeedAssault
SpeedAssault's Avatar
03.16.2009, 12:29 PM
I'm back ! I got wheels
Help me with suggestions on an ESC !!
I dropped in my Mamba max and 12 nimh cells !
I'd say it maybe goes 22 mph with locked 4wd
so Shopping for a ESC
Mamba monster = only 6s lipo , possible 50 mph with Two 3s lipo 5000
MGM = 10 S lipo max , speeds over 70 mph maybe 80+
Car Weight
7.5 lbs
with Motor no battery 9 lbs
Loaded with 12 Nimh cells 12 lbs
Work To Do:
Motor needs to be lowered onto chassis
Bigger Shocks
Neu motor, not sure which one, maybe 1515
Needs Front Differential or a Xray Trans diff
ESC options:
MMonster
or
MGM 9032 Car/Boat controller 90 Amp
Latest Firmware installed! Future updates via computer download.
New "traditional" style construction with dual heatsinks!
Perhaps the ultimate "big truck" brushless controller! Dual Heatsinks, direct soldered battery and motor leads, 150000 rpm capability( with 2 pole motors), a 90amp capability with up to 32 cells or 10s LIPO packs!Programmable Lipo voltage cutoff, small size. This is among the best controllers available for high voltage brushless applications!
other high power ESC's 100-250 amp
ID:	6605   Click image for larger version
ID:	6606   Click image for larger version
