03.16.2009, 03:43 PM
When jumping a wire was ripped off the cold joint of the battery splitter. Definitely some sort of cold solder joint or shearing force, All temps were fine and there were no signs of overheating when i was jumping...
I was running 12/46 while jumping, but that pinion flew off and was lost so i was running 10/46 when it blew... And always before my runs I check for anything loose screws, wires, etc... Nothing else seemed like a bad solder joint, especially with the way the splitter was soldered, I dont think they would've held together under a cold joint
