crazyjr
crazyjr's Avatar
03.17.2009, 09:47 PM
The velineon is a great setup, but if you set it up like mine, you'll have trouble finding a battery that fits. Most people stick the esc to the rear tower or on a shelf over the transmission, I put mine on the chassisand use it for holding the battery in place. I use a 5s 2500 25c flightpower and a 1200kv basic XL from lehner with a quark 80 amp car esc (though i could have gotten away with a 60 amp model easily) This is not a speed car, though its good for 40's, with current gearing, it could go faster. I built it as sort of an efficiency experiment, I can get 30 minutes + out of the 2500. The first thing you need to do is put a set of red springs on front and greens in the rear (if set up like mine) it'll get some stability back into it. as far as setup, Medusa is a great motor, but i don't want to recommend a kv till you say what battery you plan to run.
