12.10.2005, 04:27 AM
the max poweroutput of a system depends on the quality of the cells. if you use bad cells, your output power will terrible..
if you use IB3800's, the 6 cells should be able to put down 6-800 watts.. with a crappy pack of 20 dollars, i don't think it will be more than 250-350 watts..
