03.18.2009, 02:25 PM
I have one of the king motor baja 5b knockoffs, so you can take this however you want. There is no comparison between it and nitro. I have not touched a screw on the carb at all. I have 2 gallons on it, if it has set for a week or so, you may prime it a few times, but usually I put full choke, pull once maybe twice, and you will hear it hit, then open the choke, and 8 times out of 10 it will start 1st pull. If you have been playing with at all that day it will start first pull. It was boggey down low when I first got it, put a pipe on it and it took all that out. It may have more in it, but I really havn't felt the need to mess with it any more.
