Thread: My MMM settings
03.18.2009, 04:59 PM
Originally Posted by phatmonk View Post
What is throttle deadband refer to?
Just the "narrowness" of the neutral range. The narrower it is, the earlier it starts to move with just a slight touch of the throttle.
Originally Posted by Jeremy1976 View Post
So you think I should set it back to 10? I raised it to 15. The timing that is.
I would, but I try to set my stuff up so it runs as cool as possible without sacrificing performance. It won't hurt anything to keep it higher (as long as temps are ok), but you don't get a lot of extra output. Keep it higher if you want, just monitor temps and maybe experiment to see which setting gives you the temps and performance you want.
