MetalMan
MetalMan's Avatar
03.19.2009, 03:43 AM
Originally Posted by SunnyHouTX View Post
So if I remove the center diff of my truggy and replace it with the 770Kv Castle outrunner, it should be OK, correct? Max RPM with a fully charged 6S is about 19,400. Run times should be much longer than what I get with my Medusa 36-70-2000?
Thanks for your input.
Can't comment on the max. RPM of the Castle outrunners, but as a guess I would say that RPM is too much.
Also, assuming a truggy diff ratio, your theoretical top speed is past 60mph which is IMO too much stress to put on a reasonably sized outrunner.
A kv of up to 550 will net a top speed of about 45mph, which is the highest I think you should shoot for (again, my opinion). Outrunners don't make the same power inrunners do.
