03.19.2009, 11:00 AM
Unless you run 2.4ghz keep the rec away from the esc and motor, as they will mess with reception.
I generally place the esc near the motor and put the rec on top of the steering servo. Do you have the lay down or stand up servo on that hyper? I cannot remember what my 7 had... I think it was a stand up type. So lay it on its side and you will have some space to mount the rec on top of it. Can you move the fuel tank side tray forward and mount the esc behind it on the chassis? Layout will look a bit funny, but it will be closest to the motor. Or you could mount it in front of the tray across from the servo, but your motor wires will be long, which is never a good thing.
