Thread: My Losi 8ight T
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.20.2009, 06:06 AM
Went down to the track this afternoon and put through a couple of packs. First pack, 4s Hyperion, ran for about 20 mins and had an absolute blast getting to know this truck in track conditions. She drops the nose off the jumps pretty quick if you don't leave the top with a bit of power, caught out a few times in the first lap . Turns nicely off power so far into the corners but would like to try the Smart diff soon to see if she reacts more positive to on power corners. One thing I do like about this truggy is.........they can handle the cartwheels well
Temps after the Lipo went down with the 4s......ESC 149, Motor 150 and Lipo 105, ambient 75 not too bad but a little on the high side. I am going to try the 48t Spur, 15t pinion and see if it will make any difference.
Temps after 8 minutes on the 5s (Zippy) and leaving for half an hour after the previous 4s run........ESC 158 (fan didn't come on either), motor 163 and lipo 95. My lipo's are running cool but the electrics are getting pretty hot and I am not hard out racing, just getting used to the rig and stick around half throttle through the track and hit full along the back straight for approx 3-4seconds. More playing around with gearing to get them in check I think is needed.
Has anyone put scoops on the side of their bodies to let air flow over the motor and ESC? I was thinking of doing that as the electronics are not in direct airflow with the hole in the front window to the hole put in for the Nitro Motor of the stock 8ight-T body............thinking out loud, I hope it's not a stupid idea
I like it.......I LIKE IT ALOT!!!!!!
