Originally Posted by Sammus
But more torque isn't a reason, if you wound an inrunner to have the same super low kv as an ourtunner, it would also have huge amounts of torque. Thus I can only imagine it's to do with the efficiency of the motor...
A super low kv inrunner would make ALOT more torque. But you also have to consider the pole count.
Most outrunners are 12 pole motors.
The inrunner would also need a larger diameter armature to match the torque of the outrunner.
