03.20.2009, 06:26 PM
I did something similar with my maxx saver. Instead of using nylon washers next to the spring, I used a steel washer for a #10 screw above the whole assembly (in your pic it would be where your finger exposes the blue aluminum shaft at the top). It works the same, but I think your way looks a little neater the way the washers fit inside the saver assembly.
G-Maxx MMM/1515 2D
T4 Factory Team MM/Lehner 3600XL
RC18t 5400 Mamba
MGT 8.0 conversion MMM/1521 1.5D
