03.20.2009, 08:41 PM
Yes, the powered ESC is sending BEC voltage to the brains of the other ESC. You could remove the red wire on one of them, but I would suggest using a Y harness instead and removing the red wire on one leg of the Y. Otherwise, programming the ESC with the wire removed will be a PITA.
