12.10.2005, 08:29 PM
Originally posted by mmdooley
I think it looks great! I have been thinking about this for awhile, Tell me what you think. Would the motor and ESC be cooler if the fans were set to "pull" air away from the motor and ESC? Instead of blowing air over them? I worked in a factory with alot of electrical systems and no air conditioning. And they (maintenance) always pulled air away instead of blowing air over electric components. Just a thought :D
To pull air, you have to make sure the device to cool is in the air flow. Since there is no air duct directing air directly over the motor/ESC, some air would sneak in right at the fan instead of over the motor/ESC. In this case blowing is better than sucking (please, no funny comments! :)).
In electrical/computer systems, the exhaust fan pulls air through the whole case so it has to go over all the components to cool. shoving air into a case does cool too, but the air tends to just swirl around without a direct path of flow reducing its effectiveness.
