Thread: Airbrush
Gee
A Horse's Ass
Gee's Avatar
03.21.2009, 11:02 AM
Originally Posted by maxair45 View Post
I'll look into a panckake compressor and a regulator. I was thinking after I was done painting I could just run some water and WD-40 through the system(instead of paint). Is this sufficent or should I do a complete tear down?
That fuel tubing tip really helps thanks you.
I've only used the Faskolor paint. It cleans up with hot water. Jeffs right about the tank it would loose pressure and you always be adjusting your brush due to it. It would be a pain to use it that way but if you were close to a air compressor you could get by with it until you get a little air compressor.
