Originally Posted by Ascender
Linc, if I did keep the Zippy batts, what gearing and ESC settings would you recommend?
well, looking at the flux gearing if you want to do around 40mph on 6s you will need a 14t pinion. punch control at 50 percent is a good start. i usually adjust the start power to my liking, if the truck does not cog with very small throttle input from a standstill it is ok, if it does cog or glitch raise the start power. leave the timing alone, no need to fool with that. just run a smaller pinion and you should be good to go.
