squeeforever
squeeforever's Avatar
03.23.2009, 03:32 AM
Your not SOL just yet. When you say its unloading, is it just one of the wheels (should be the inside wheel) or both? If its just one, you need heavier fluid up front. Either way, I'd try some heavier fluid up front and that should tame it done a bit. If wheelies still persist, then lighten up the center a little.
