skellyo
skellyo's Avatar
03.23.2009, 10:32 AM
Originally Posted by fastbaja5b View Post
I run mine on 4s, 20t pinion, 100% punch control and 0 degree timing and it's still a handful.
100% punch control? That's way too much if you ever jump it. You'll never be able to correct it in the air with that much punch control.
FWIW, I think 4S with the 20T stock pinion is about perfect for bashing. If you haven't done so, put some tires on other than the crappy stockers. The reduced diameter and reduced ballooning of better tires will make a world of difference in handling.
