03.23.2009, 06:52 PM
The new v3 diffs don't use an 8mm drive cup on the diff pinion - the drive cup is now included, actually. :)
The V3 diffs are smaller than their predecessors and actually uses a different diff altogether(smaller size than the larger Ofna/Hot Bodies size used previously) - the pinion is actually 5mm at the drive cup area on the new hybrids(similar to Mugen diffs).
So Mike, what diffs. will work then w/the v3...so you are saying that Mugen diffs will work? I was hoping against all hope that my HB diffs would fit...
I figured it out!
