Originally Posted by What's_nitro?
I take it your KB uses membrane switches? Why not pull it apart and clean the contacts with DnA? They should all be printed on one piece of plastic, so assuming it is "take-apartable" it will be easy to clean.
it is actually 2 layers of plastic with printed circuits on both. in between them is another layer of clear plastic with holes which allow the two sheets to make contact when the keys are depressed. i have eyeballed them quite a bit and cannot find anything that would cause a bridge... i guess i burned it out.
