03.24.2009, 04:31 PM
The only difference between the 2.5 and 3.3 belts is the front and rear belts. The center is the same since it uses the same pulley size. The f/r small pulley went from 15T to 20T IIRC, so a larger belt is necessary.
You might want to just brace the chassis. I know that the belt had a ton of play on mine until I braced the chassis. If you push down on the center belt, you can actually see the chassis flexing.
This is true, I am thinking about the front and rear belts. I will rig some sort of brace up, I have a few ideas in my head, but will wait for the neu cells to come in before I do anything.
On another note, I destroyed the front belt just now... I guess I get to order a new one, or maybe check the LHS (waste of time usually). The stupid hole in the chassis at the front allowed a rock in and it jammed between the diff and the front upright/shock mount. I may add a hole in the front to allow debris out... Bad design not having a sealed front and rear belt setup... Maybe I can make something. I was thinking about a new chassis for the beast...
