Originally Posted by e-mike
next time i will try to gear up....so its the first time that ive seen a motor that ive proble to set-up correctly....
I see that you used the lowest timing for the medusa. As far as I know 4 pole motors aren't efficient at that kind of timing and they heat up quite a bit. Try increasing the timing. Head over to e-savage.com and look out for Kostaktinos_mt. He is very knowledgeable when it comes to motor efficiency.
Your motor was probably spinning too fast. There is a range of rpms which the motor will operate at its max efficiency. Check with medusa and gear it accordingly.
I am very interested in getting a 70mm medusa too. Do drop me a note on how the motor performs when u get your motor back. :D
