Originally Posted by Jabe
I have tested few timing settings and 10 was most powerfull and still kept motor cool.
If you run too low timing, you lose power and motor gets hot (as seen here).
And im using 2200kv 80mm medusa.
Your motor should run more efficient and cooler on a lower timing setting.
